new distributor
Old Jul 30, 2010 | 01:51 PM
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
new distributor
Hi i got a 1986 trans am 305 tpi and i jus bought a proform mechanical distributor, and my stock distributor has an electronic advance on it with a 7 pin ignition module. so my question is will it be alright to jus stick with this new mechanical distributor even tho it does not have the hook up to the ignition module or wat would i have to do to make this one work, thanks.
Old Jul 30, 2010 | 10:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: new distributor
You can't make it work. Computer controlled car has to have a computer controlled distributor - period. The computer takes readings from all the other engine sensors and adjust timing on the distributor. If it's not connected, you'll get all kinds of codes, the car will run like crap if it runs at all, you'll have no timing advance or retard at all.
The only way to use a mechanical advanced distributor is to swap to a non-computer controlled carb setup.
Return it, or sell it - you can't make it work.
Old Jul 31, 2010 | 08:41 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Re: new distributor
This is about the only way to do it. You can buy a MSD or Similar distributor for a decent price)
Old Jul 31, 2010 | 12:38 PM
Re: new distributor
is this wat i should be lookin for http://www.summitracing.com/parts/DUI-12611BK/
Old Aug 1, 2010 | 11:19 AM
Car: 1992 RS
Engine: Carbed 350
Re: new distributor
Looks like it. However, Autozone/Advance/Oreilly's/whatever carry distributors for 1/2 that price - they're remans, won't come with coil/cap/rotor - but they should be guaranteed - worth looking into.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
