Another Hatch Pull down issue, Help plsz..89 Iroc
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
I have put two different pull down units on my 89 Iroc. On both of them when I shut my deck lid the motor pulled the hatch down really tight, almost sounded too tight. When I go to open the deck lid it will release but the motor on both units would not come back up. Is there a switch or contact that tells the motor to stop going down and to come back up? Any help would be great. Thanks, this is getting frustrating!
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Walking The Tightrope
Re: Being pulled down too tight.
The pull-down unit mounts in oversized holes allowing adjustment.
Re: Not going up.
In the pull-down unit there is a reversing switch that causes it to come up that you can access thru the opening where the latch is with a screwdriver or pencil.
Sometimes that switch needs to be flipped.
Happy Racing!
I Dont Mind Wreckin On The Track, No Paperwork To Fill Out
Re: Not going up.
Happy Racing!
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Re: Walking The Tightrope
NIna,
Thanks for your help. I cant locate the switch youre talkin about. I have the entire unit out of the car. Is it on the black portion of the latch or somewhere else? Thanks again.
Transmission: 765R4
The reversing switch is about a half inch more towards the rear of the car than the latch is.
I forget if you need to flip it up or down but it will be obvious because it when its in one position it can only move in the other.
Happy Racing!
Happy Racing!
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Hey guys,
Thanks for the help. I called the guy from top down solutions. He said my adjustment was off. I raised the entire unit. He said mine never went down far enough to engage the reverse switch. I raised it up as far as it would go and it started working instantly. Thanks again for your help and responses.
Axle/Gears: 3.45, 3.27, 3.27
Yep. that's what I would have said. Oh wait, that is what I said. Glad you were able to get the hatch adjusted properly.
Lon
Lon
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Yeah man, I appreciate it. As soon as I raised it up some it engaged and started working. Talking about feeling real stupid!! Thanks again for the time to explain and save me some loot in the process.
mustangman65_79
Aug 11, 2015 03:17 PM
