Fuel pump castastrophe?
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Upon installing the lb9 305 tpi engine harness and computer over the original lb8 v6 harness and computer, my fuel pump relay will click, but no pump operation. Pump was fine before the swap, assuming that 12 volts are at pump, ill check tommorow, is it possible i have a c100 pin in the wrong place? In c100 diagrams, no fuel pump wires are listed at the connector, but i noticed the orange wire off the fuel pump relay seems top run to it. Any help greatly appreciated
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
