no fuel pump operation after lb9 engine harness swap
Old Aug 9, 2010 | 10:29 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
the fuel pump checks out okay, the green wire from ecm is putting out a signal, I have 12 volts at orange power wire, good ground. Wondering if thec207 connector or c100 connector has fuel pump wiring, all suggestions of c100 views show no fuel pump wiring, If anyone knows where the tan/white(gray) fuel pump fed wire is routed throughout body, please let me know as Im using only the computer and engine harness wiring from a v8. If i jump a wire from the fuel pumps tan/white(gray) at pump connector, to white tan (greay at relay, i get a constant fuel pump power with KOEO, pump will constantly run, any help is appreciated
Old Aug 11, 2010 | 11:07 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
See C Señor
The gray wire from the relay goes thru C100.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
