Idle Air Sensor problem
Car: 1988 Pontiac Firebird Formula
Engine: 5.0 Throttle body injected
I just recently put a brand new Idle air sensor into my firebird yet it still has the problem of not liking to start...
when it starts up it idles like CRAP, pulsating to 2000rpm all the way back to around 400rpm... it does this for quite a while and then it either shuts off or gets a steady idle.... I tried just about everything. I am a mechanic myself and I am still dumbfounded about this... I just dont know what direction to go in now... Ive even thought about getting rid of the car
the only way I can drive it cold is if I hold the gas pedal down as I drive and even come to stops by pressing both the gas and the brake together (which is very dangerous btw)
someone please help. I dont know if it is wiring or what
...the only way I can drive it cold is if I hold the gas pedal down as I drive and even come to stops by pressing both the gas and the brake together (which is very dangerous btw)
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Sometimes Pressing The Gas And Brake Together Is The Fast Way Around The Short Tracks
Did you scan for codes?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Happy Racing!
Re: Idle Air Sensor problem
yeah and there was just the same codes as before.
1. 12- No reference pulses to Electronic Control Module (ECM).
2. 14- High temperature indicated at engine coolant temp sensor
This one is all set.. I let the engine run too hot while I was putting in a new fan turn on switch.
3. 22- Low voltage at throttle position sensor OR Fuel cutoff relay circuit open or shorted to ground.
4. 23- Low temperature at manifold air temperature sensor OR Throttle position sensor error.
This on is quite tricky to me because the previous owner had plugged up the manifold air temp. sensor with a metal plug and left the sensor hanging. and After I went out and bought a new sensor and plugged it in the car would not idle and it would throw flames from backup out the top of the intake.... This one I really need help with.
5. 43. Low voltage at electronic spark timing circuit.
6. 44. Oxygen sensor lean
Transmission: 765R4
If there were no codes in the past, and now all those codes appeared at the same time, I would suspect a damaged, or loose ECM connector, or bad ECM.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Happy Racing!
Re: Sometimes Pressing The Gas And Brake Together Is The Fast Way Around The Short Tr
I have same issue as you on an 87 firebird, I get a code 34 cleand then replaced the Mass airflow sensor, no luck there, tryed for many hrs me and my brother to get air sensor out with no luck till the rachet actually gave out, using a os sensor socket tool as well
many painfull ingerys including pulling my back, was having issues jacking car up so lost the connstion to plug the o2 sensor thats in there back in lol
many painfull ingerys including pulling my back, was having issues jacking car up so lost the connstion to plug the o2 sensor thats in there back in lol Re: Idle Air Sensor problem
He has a TBI, so no MAF to speak of
Clear the codes so we know whats current and whats from the PO's wrong doings
Pull the top off the breather and crank the car up. See if its flat out DUMPING fuel in. Next try unplugging the CTS near the water neck (yel/blk wires) and firing the car again
Sometimes a bad CTS will stick at a very negative value so the ECM thinks you're driving in the arctic circle and adds fuel accordingly. For LO3s, it means running awful, for LO5s common in trucks, it means not running at all. Unplugging it will throw a code for no CTS signal, but the ECM defaults to a safe value
If that's not it, do the same test for the IAT in the bottom of the breather pan
eightsixseven
Dec 16, 2024 01:50 PM
mdtoren
Aug 16, 2015 05:45 PM
