No Tailights at all...
Old Aug 17, 2010 | 10:30 AM
Horton's Avatar
I recently just got an 1989 Pontiac Firebird and went to replace the bulbs in my tail lights to get them to work. After replacing the bulbs and the reverse light bulb they do not work, not even when the headlights are turned on. I do not know what all kind of wiring has been done i do not know what to check as far as getting them working. Any suggestions would be greatly appreciated.
Old Aug 17, 2010 | 11:08 AM
Stephen's Avatar
Car: 87 GTA
Re: No Tailights at all...
Fuses are a good place to start looking.....
Old Aug 17, 2010 | 01:54 PM
Horton's Avatar
Ive checked all the fuses and none of them are blown or in the wrong spot as i can tell. i feel like it may be a relay or something because the blinkers wont blink they just come on. it alot of crappy wiring done to it but it all still works i just have a bad feeling someone f*@#%ed up somewhere when they were "fixing" it the last time and didnt care to tell me about it.
Old Aug 17, 2010 | 04:44 PM
Stephen's Avatar
Car: 87 GTA
If the dash light comes on & stays on, or flashes double fast? That is generally an indication that 1 of the bulbs in that circuit is dead.
It can mean at least 1 bulb is not getting power, which the car will only see as a light is out & turn the light on solid or double fast blink. Go to each bulb socket & see if any are not getting power. If you find one, trace that wire back & see where/when it is losing power.
Old Aug 18, 2010 | 09:46 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Taillight Fright
Perform the instructions in post 4 for the blinkers, then for the taillights put the lightswitch in the “park” position.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the brown wire at the switch.
If you have power there open the hatch and unplug the connector located at the left rear of the car.
Probe the
brown wire at the connector.
If you have power there the problem is the wiring between the connector and the tail lights.
If you don’t have power there is a break from the switch to that connector.
Then you just have to trace that short run of wire.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Aug 20, 2010 | 10:47 AM
Horton's Avatar
Re: Taillight Fright
Well i got my tail lights to working last night. The people i got it from left the ground wire off and just laying under the carpet. Now my problem is that they have it rigged up in the fuse box where when i push the brake pedal the tail lights come on with the hazard lights and the dash lights and the buzzer to let you know your door is open but this only happens when the headlights are off. When they are on it wont do any of this and only my driving lights will stay lit. So if anyone can get me a wiring diagram for the tail lights and blinkers and everything i would greatly appreciate it, or maybe just a whole wiring diagram for pretty much everything i guess. Thanks if you can help.
Old Aug 20, 2010 | 10:55 AM
Stephen's Avatar
Car: 87 GTA
Wiring Diagrams
Old Aug 22, 2010 | 11:50 AM
Horton's Avatar
Thanks for all the help. The only help i need now is some exhaust. I need from the manifold to the back of the car. I would prefer a complete exhaust system i can buy for a legitimate price. so if anyone has any ideas please send me a link or information please. Thanks again..
Frozer!!!
Jan 19, 2024 04:55 PM
buckeyecelt
Sep 24, 2015 05:50 AM
90formulaVortec
Sep 7, 2015 06:54 PM
Dquickshift
Aug 12, 2015 06:21 PM
zupmanZ28
Jul 21, 2001 09:07 PM
