Where are these wires!
Old Aug 19, 2010 | 08:48 PM
sethorama's Avatar
ok thanks for looking
car is a 1992 v6fi
it now has a 350 carb motor in it
i bought the care with the v6 motor out
so idk if all the wires are there
im looking for the ignition switch wire for the starter. where can i trace this wire from?
I have a hei distributor im looking on how to power it up with what wire threw the drivers side wiring
thanks
Old Aug 19, 2010 | 09:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Where are these wires!
Starter should get a group of wires that are all fusible links (have a small plastic white thing inline), as well as a large wire that comes from battery pos - those connect to the large terminal on the starter. Then there is a purple wire that goes on the smaller starter connector. All these should run from the pas edge of the radiator, under the exhaust manifold on pass side, to the starter.
The dist wires should exit just about dead center of the large wire loom that runs over the back of the block/bellhousing.
Here's wiring diags for most all 3rd gens - find the original year/engine and then you can trace wire colors - knowing the colors might help you find them.
http://www.austinthirdgen.org/index.php?pid=19
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
