code trouble help!! - ecm wont flash codes
Old Aug 21, 2010 | 10:50 PM
Black Flies's Avatar
Car: 1992 Z28
got a very frustrating prob with my 91 z whenever the service engine light comes on, and i have not been able to pinpoint it because the car will not flash the trouble codes when i try to check them...
when i ground the plug and turn the key on, the engine light shines, but does not flash.. not even the 12 code. i have always relied on this to solve my problems with my other cars
is there another way to get the code read?
autozone says they cant do it.
help please
Old Aug 22, 2010 | 12:15 AM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: code trouble help!! - ecm wont flash codes
There's 2 "different" setups to ground out the ECM. It's in the tech articles if you need a refresher.
If your car is a automatic you will hear the converter lock/unlock as you ground/open the ECM circuit. Put the key in the run position with the motor off and try the 2 different possible patterns to ground the ECM and listen for the converter, you can't miss it unless you are in a really loud area. Once you hear the converter the SES will show the flashes. If you ground AFTER the key is in the run position you'll want to turn the key to OFF and back to run so it will start over from the beginning with the flashing.
Old Aug 22, 2010 | 07:54 AM
Car: 1992 Z28
cant seem to find what you are talking about in the tech section
but ive tried everything.. even ways that i know are wrong
Old Aug 22, 2010 | 10:39 AM
Doom86's Avatar
https://www.thirdgen.org/service-eng...ht-error-codes
It is on the front page under Thirdgen Tech FAQ.
My 86 is pin 6-12 and my 91 is 5-6 and I always forget which is which when I go to pull the codes so I usually pull them as I described before.
Old Aug 22, 2010 | 08:04 PM
Car: 1992 Z28
yea.. still no worky
im lost
Old Aug 24, 2010 | 10:52 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ECM Mayhem
The ECM is defective or has a bad connection going to it.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
BumpaD82
Feb 26, 2016 02:57 PM
eustodp
Sep 20, 2015 05:09 PM
64Chief
Sep 12, 2015 08:05 AM
RyanJB
Sep 2, 2015 01:27 PM
