Gauges pegged out fuel, oil, tach
Old Aug 25, 2010 | 06:13 PM
91t5fbody's Avatar
I just recently got my car running it has sat for around 7 maybe 8 yrs and when I went to start the car while turning over the gauges pegged out all the way right, it was the fuel, tach, oil from what I remember. I was wondering if anybody might know what could be going on??
Old Aug 25, 2010 | 06:27 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: Gauges pegged out fuel, oil, tach
Did you get the car started? If you did they should come back down. They do sometimes when you try and start the car with a low battery.
Old Aug 25, 2010 | 06:57 PM
91t5fbody's Avatar
yeah I got it started let it run for about 5 or so mins and the battery is brand new.
Old Aug 26, 2010 | 04:11 AM
Awesome-X's Avatar
Car: 87 Camaro
Well you can always take the gauges out real quick and remove the plastic cover and move them back down with your finger lol
Old Sep 4, 2010 | 05:35 PM
91t5fbody's Avatar
when you turn the key on they go down to normal position and when you go to crank the car they climb up and peg out.
Old Sep 4, 2010 | 06:02 PM
ls1fiend's Avatar
Car: 1985 z28, 1994 Sierra
Engine: 350, 350
Transmission: T-5, 4L60E
My water temp gauge does it occasionally. I just tap on the gauge with my finger and voila!
Old Sep 6, 2010 | 07:08 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
ive had the same issue before, my tach got stuck though, i jsut revved it and it popped right back down, with the oil pressure and fuel pegged out...id check the connection on the cluster, just pop it out and then look for any jacked up wiring, and replace it, it normally works for me
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
