code 15 help
Old Aug 27, 2010 | 12:18 PM
capsfan101's Avatar
Car: 1992 camaro rs
Engine: v6
code 15 help
i am new to third gens and i was driving the other day and the ses light came on. pulled the code got code 15 bad cts. replaces the cts and im still having problems but now the car wont idle and is running rich. does anyone know what else i need to do to fix this. the car is a 1992 rs v6.
thanks
Old Aug 28, 2010 | 12:25 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: code 15 help
did u clear the codes and do an idle relearn?
Old Aug 28, 2010 | 12:29 AM
capsfan101's Avatar
Car: 1992 camaro rs
Engine: v6
Re: code 15 help
i did clear the codes, but i still am getting code 15. i think there might be a bad ground somewhere. i am going to try a idle relearn later today.
Old Aug 29, 2010 | 09:06 AM
capsfan101's Avatar
Car: 1992 camaro rs
Engine: v6
Re: code 15 help
so after doing an idlerelarn i am still having problems and the ses light is still on with code 15. i have made its own ground so i know it has a good ground and i have disconected the battery to clear the codes but it still comes right back on. is there something i am missing?
Old Aug 30, 2010 | 12:28 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Code Breaker
What method are you using to read codes?
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Aug 30, 2010 | 01:03 PM
capsfan101's Avatar
Car: 1992 camaro rs
Engine: v6
Re: code 15 help
i am using the bridging of the ports with a paperclip. thats the only method i know of. i think i might have finally found that it was a bad connector on the cts. i have made a test connector and the ses light is now off with it and the car is running close to normal i think it just needs a good tune up and maybe an idlerelearn.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
