Quick and easy VATS question
Old Aug 27, 2010 | 09:00 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
On a '92 RS, can the VATS system keep the starter from cranking, or does it only disable the fuel?
Old Aug 28, 2010 | 06:23 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Quick and easy VATS question
Vats disables the starter by not proving ground to the starter enable relay.
Also disables fuel by not allowing ECM to power the injectors.
So, answer is both.
Old Aug 28, 2010 | 07:07 PM
Engine: that I like
OK, thanks. My brother's car developed a warm/hot start issue that acted like a starter issue, but he noticed the last time it wouldn't crank, the security light was flashing. Looks like we have the VATS to deal with, rather than a starter.
Old Aug 28, 2010 | 08:04 PM
Car: 1992 RS
Engine: Carbed 350
OK - here's a starting diagnosis: http://www.austinthirdgen.org/index.php?pid=38
Before you grab another starter, go through that - there's alot going on - I've replaced EVERYTHING, and I still have an issue somewhere - sometimes I start, sometimes I just click - but my VATS is taken out of the picture, so for me it's not VATS.
Good Luck!
Old Aug 28, 2010 | 08:34 PM
Engine: that I like
The car has never acted up when I'm around. It's only done it to my brother and it started a couple years ago. He would park, come back a little while later, then it wouldn't crank- just silence. After about 10 minutes the car would fire right up. So then we bought a starter for it, but the problem went away until recently. Well, he noticed the one time that the security light was flashing when he tried to start the car. I'm guessing at this point that the lock cylinder is worn out and occasionally not getting a good signal from the chip in the key. The car has over 200K on it.
Old Aug 29, 2010 | 08:17 AM
brian m.'s Avatar
I'm having the same prob right now except mine cranks but no fuel. I checked the code and came up with passkey which means a vats prob can anyone send me a picture of what the anti theft module in a 91 camaro rs looks like
Dkelz313
Apr 7, 2016 10:38 PM
stalkier
Dec 6, 2015 11:25 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
