the pink distributor wire
Old Aug 28, 2010 | 05:51 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
the pink wire that plugs into the BAT part of the distributor...does the other end go to the Ignition part of the starter?
Old Aug 28, 2010 | 09:52 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: the pink distributor wire
Yes, it gets hooked to ignition. Hot with key on and during cranking.
Old Aug 29, 2010 | 08:14 PM
SeriousGearhead's Avatar
Car: 1982 Pontiac Firebird Trans Am
Engine: 350ci, 882 heads, mild cam
Transmission: Turbohydramatic 350
Axle/Gears: Factory GM 10 bolt
As long as that wire has 12V (and an on/off switch) its happy. Less than 12V can cause misfires.
Caspar
Jun 19, 2016 11:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
djmarch
Aug 19, 2015 12:07 PM
penguinpanda0
Aug 15, 2015 06:45 PM
