Any bright ideas?
Old Aug 29, 2010 | 01:25 PM
SeriousGearhead's Avatar
Car: 1982 Pontiac Firebird Trans Am
Engine: 350ci, 882 heads, mild cam
Transmission: Turbohydramatic 350
Axle/Gears: Factory GM 10 bolt
Any bright ideas?
I have a 1982 Trans Am, my passenger headlight is dim and blinks slightly with the turn signal. I believe it goes out when the high beams are turned on, not sure if it still does that or not, I don't drive the car at night too often as deer are a problem where i live. I own a Neon if I get the itch to clobber Bambi. Anyways, I was curious if anybody has encountered this problem before I go digging into my wiring harness. My fuses are all good, not sure about the multifunction switch, everything works when the headlights themselves are off. Any feedback?
Old Aug 30, 2010 | 12:23 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Not Bright On The Right
It sounds like there is an open ground.
Make sure the lightswitch is off and unplug the right headlight socket.
Using an ohmmeter make sure you have less than 1 ohm to ground.
Then make sure the right low beam terminal has continuity to the left low beam terminal.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Aug 30, 2010 | 02:08 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Any bright ideas?
IIRC, there's dual ground wires from the head light harness to just under the lip of the frame on the passenger side where the battery is.
Old Oct 10, 2010 | 05:57 PM
Almost forgot I posted this, I don't have an ohm meter (yet) but I did trace out the ground wires visually and found a spot where several grounds had been soldered together. It was pretty corroded so I fixed that and everything is working just fine now. Thankyou for your help.
83 Crossfire TA
Jan 3, 2016 01:26 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
