Differant 91 92 tach issue
Old Sep 5, 2010 | 06:29 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
my tach reads way way high like 7500 rpm at idle high> i swapped the gauge cluster, the second cluster did the same thing. any ideas?
Old Sep 5, 2010 | 08:53 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Differant 91 92 tach issue
Are you sure you are swapping in a cluster from another V8 and not a V6?
Old Sep 5, 2010 | 08:59 PM
Transmission: autos
That was my first thought, but the first cluster was true to the mileage and so is the second one. I never have had the second cluster in a running car, until today but the chance 2 clusters had the same issue I can't believe. First cluster was in the 91 l98 car second was in a 305 tbi car
Old Sep 7, 2010 | 09:54 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Whacky & Tachy
2 or more tachs of the same vintage can show similar erroneous readings due to the fact the parts which go defective age the same way.
There is circuitry in the dash near the tach.
It’s contained on a small plug-in PCB or integrated in the main board.
On the PCB you’ll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder the potentiometer, measure it and install a matching resistor.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Armored91Camaro
Aug 25, 2015 12:01 PM
crazynights
Aug 21, 2015 06:53 AM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
