Troubleshooting HEI Distributor
Car: 92 Camaro RS
Engine: 77' 350 bored 355 Holley carb
Transmission: Turbo 350
77 350 with HEI Distributor. Had a no spark problem again today. Car running fine now but had to try and wait a bunch of times. It stopped while driving three times but started right back up first two times. I want to test all components of Distributor to not get stranded. There was 12v going into Battery Terminal on distributor
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cuts Out But It’s Not An X-Y Plotting Sheet Metal Cutter
Wire up a small 12 volt bulb (a side marker bulb works best).
Connect one lead to the BAT terminal at the distributor, and the other lead to ground.
Make the wires long enuff to bring it into the cockpit.
The next time the engine cuts out observe if the bulb is on or off.
Happy Racing!
Make Noise, Turn Left, Repeat
Happy Racing!
Car: 92 Camaro RS
Re: Troubleshooting HEI Distributor
this is what ive read to test
1st test- primary resistance, tach to bat terminals is near zero -
2nd test - secondary resistance, rotor button to ground -
3rd test - secondary resistance, rotor button to bat terminal -
1st i get 3.5 ohms ( not close to zero?)
2nd i got 11.2k ohms
3rd no reading (is that infinate?)
Transmission: 765R4
1st i get 3.5 ohms
Happy Racing!
Engines Run Best Right Before They Blow Up
Car: 92 Camaro RS
Re: Cuts Out But It’s Not An X-Y Plotting Sheet Metal Cutter
i actually ordered a new dist today. brand new. piece of mind
Car: 92 Camaro RS
have meter hooked to wire going to battery terminal of dist. reading 12v. car died a few times and each time still said 12v. was watchjing the whole time so didnt drop then go back
Transmission: 765R4
10-4 on that.
Even tho your new distributor is on it’s way if you want to troubleshoot the old one further probe with an audio amplifier to the connection from the module output to the coil primary.
When the engine cuts out, crank the starter.
If you hear clicking when you do that, but the car won’t start, the ignition coil is bad.
If you don’t hear clicking when you do that, the module or pickup coil is bad which can be further diagnosed to determine which.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
Happy Racing!
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
91, button, camaro, carb, components, dist, distributer, distributor, hei, holley, hooking, rotor, sbc, shooting, test, testing, trouble, troubleshooting
