Need help on what this wire is.
Old Sep 9, 2010 | 05:14 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Hi, I found a thick red wire that ran from the inside of the car to the hood (think it was by the battery?) anyway its got a built in fuse thing on the wire, a ring terminal on one end, and the other end looks like it got cut off. Does anyone know where it goes to? or is it some aftermarket radio wire? I'm not getting fuel to the carburetor and trying to see if it's a wire issue. Thanks.
Old Sep 9, 2010 | 07:20 PM
0pyders's Avatar
Re: Need help on what this wire is.
GOT A PICTURE:
Old Sep 9, 2010 | 07:40 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
That looks like an aftermarket installation wire to me. Unless someone rigged it to your fuel pump. I dont think its the problem.
Old Sep 10, 2010 | 11:06 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
looks like a wire for running the + to a aftermarket amplifier..
Old Sep 10, 2010 | 02:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Pump Slump
That car should have a mechanical pump therefore the wire won’t have relevance.
Disconnect the line at the carb.
Using a gasoline resistant, non-sparking cup to catch any fuel, crank the engine to see if there is fuel flow at that point.
Do all this type of work away from dwellings and have extinguishers handy.
Happy Racing!
Engines Run Best Right Before They Blow Up
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
