3rd BRAKE LITE ???
Old Sep 9, 2010 | 06:03 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
3rd BRAKE LITE ???
i'm almost at the end of my little fix-it's list on this car . 3rd brake lite is one of the next . does anyone know if a 91 uses the same bulb's as the spoiler mounted ones ? if so how many ? yes , if they are the same i will be going to radio shack . thanks in advance .
Old Sep 9, 2010 | 09:22 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: 3rd BRAKE LITE ???
you mean the one up in the window? IIRC its a 3156, you can get them at checker, autozone, walmart, just about anywhere that has bulbs, its simple to replace just 2 torx screws and pop it in
the question is: is the bulb burnt out or is it not getting power?
Old Sep 10, 2010 | 10:36 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's NOT the same as the spoiler mounted light - it's a single bulb.
Old Sep 10, 2010 | 04:29 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Thanks for the update....its 3165. I just replaced mine.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
