My starter is sparking?
Old Sep 9, 2010 | 08:04 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Have everything hooked up right, have electricity to the rest of the car, one of the wires with a fusible link was broken or cut, I spliced it, and put it on the terminal, then + batt wire, it cranked fine on first test, then tried twice more and it just sparked and made a click sound, also the wire going from starter to solenoid is exposed a bit, seems like the spark is coming from that or in between that and the switch terminal....Can't figure out wth is wrong here...
Old Sep 9, 2010 | 08:36 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: My starter is sparking?
Is it a new // rebuilt starter?
Old Sep 9, 2010 | 08:45 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
Sounds like a bad connection or the exposed area may be making contact with something. Cover any exposed wire with electrical tape for now. I would shrink wrap it once you solve your issue. The starter draws alot of current. If you have a weak connection the starter will find it. Make sure all your cables and wires are tight and clean.
Old Sep 10, 2010 | 12:55 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Splice N’ Dice
Jump that connection to see if the spark goes away.
(When you spliced the wire with the link, hopefully you didn’t bypass it.)
Happy Racing!
Engines Run Best Right Before They Blow Up
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
meeklay812
Oct 1, 2015 03:46 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
