what are these cut wires for 90'ish camaro tpi harness
Old Sep 17, 2010 | 04:36 PM
Jeffs82TA's Avatar
assuming these to be the coil wires. this is a speed density harness so is at least a 90-92
last but not least. A member is interested in buying this harness, is 75.00 a fair deal for this harness even with the couple of snipped wires. over all the harness is in nice shape.
EGR relay ?????
purge solenoid ?????
fan switch ?????
MAP or TPS ????
in this picture bottom center you can see the battery cable and cut alternator charge wire (I assume???) right by them is two other cut wires red & orange I think. these were near the battery fuse holder for fan ????
Old Sep 17, 2010 | 05:17 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: what are these cut wires for 90'ish camaro tpi harness
Okay...... First photo, you are correct. Pink is coil+, white is tach wire. Second photo, yes I would say those were EGR sol. wires. Third photo, purge solenoid seems about right. Fourth photo, definitely fan switch. Fifth photo, black, gray, and blue are TPS. Black, gray and light green would be MAP. Sixth photo, The fuse by the battery is the fuel pump fuse. The red wire is power to the junction block. The orange is power to the cooling fans from the junction block (should have a fuse link at the end).
Old Sep 17, 2010 | 05:33 PM
Jeffs82TA's Avatar
There was no junction block on this car. If you look by the battery cable bolt there is a connector two wires I think. would that be the fan feed wires? I recall the two wires orange and red being behind the battery towards the tire. so would both of them go to a fuse holder for the fuel pump?
Old Sep 17, 2010 | 06:29 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
My diagram for the '90 shows a junction block. I would assume that those wires are for the fuel pump and cooling fans. The cut end of the orange wire should go to the cooling fan relay and the red to the fuel pump fuse. I think both these circuits go through the two wire connector. You can test with an ohmmeter to verify this.
Old Sep 17, 2010 | 06:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The last ones - fuel pump wires - don't think either has anything to do with cooling fans. red runs in from batt, orange runs out to oil pressure sending unit, fuse between.
Old Sep 20, 2010 | 04:06 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
camaronewbie may be correct. I cant tell from the photo where the fuel pump fuse is in relation to the two pin connector. The fuse holder should be close to the batt+ cable end. At this Point I suggest you locate a factory diagram for the vehicle the harness came from. Mitchell 1 On Demand and/or AllData is available at most county libraries. Both have reasonably good diagrams. The buyer will need this diagram to install this harness. He/she will also need a good digram for the car they are installing it in. Otherwise these questions of what goes where become a huge issue. And we all hate to see smoke.
customblackbird
Aug 15, 2021 10:16 PM
midge54
Sep 2, 2020 07:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
