Tach wire behind inst. cluster / remote start?
Old Sep 23, 2010 | 02:57 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Hey All! Posted this up in the car audio board with no results. Thinking maybe I posted in the wrong place.
I have an '86 IROC that I am in the process of installing a remote start alarm in. I am looking for a tachometer signal wire behind the instrument cluster, in the intrest of saving my underhood from even more clutter. Any one know what color/location it is?
Car is an '86 IROC TPI auto.
Thanks!
Old Sep 23, 2010 | 03:07 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Sounds Remote
It’s White, it goes to one of the connectors in back of the dash.
Of course once you believe you’ve found it, you can verify with an ohmmeter.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
Old Sep 24, 2010 | 01:00 AM
Re: Tach wire behind inst. cluster / remote start?
Thank you!! I really appreciate it! Plain white wire, no trace... Got it!
Old Jun 13, 2011 | 11:38 AM
dark scorpion's Avatar
Car: 1990 gta
Engine: 5.7 l 350 v8
Transmission: automatic
On my 1990 gta there are to connectors with wires to them. One connector is brown, the other is gray.
On the brown connector there is a white wire and it is lables to #1 not #7.
What should the reading be when I meter up to it (at start up, and idle,
and accelerate)?????
Dont' want to splice into the wrong wire.
Looking to do the same thing for my remote start.
I have reservations about going to where it connects to the coil.
Craig
Old Jan 4, 2012 | 10:43 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
did we ever resolve this? Having issues with my clifford not getting a clean signal and its starting to **** me off, ive tagged the white wire at the coil (going to the tach not the icm) as well as at the cluster, tach signals are in AC but i cannot get a clean consistent AC signal to my remote start which kills it with an over rev or under rev ( DEI makes their stuff shut down the sequence if idle drops too low or rises too high)
Biggest problem is that the singal jumps from 3-4 volts AC just sitting still at idle, no rpm change visible by the tach or audible by engine noise, ran virtual tach which over ran my starter and also tried voltage sense which didnt crank long enough....oh and to add to my attempts i soldered into the tach wire, at both locations (t-taps dont play well with AC)
Ive installed god knows how many remote starts (DEI at that) and ive never run into this type of a situation......
soooooo ideas?
Old Jan 5, 2012 | 01:56 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Why do you need the tach wire for an alarm?
Old Jan 5, 2012 | 04:37 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
It's for the remote starter. It lets the remote starter know when the motor starts.
Old Jan 5, 2012 | 04:42 PM
Orale.
Old Jan 5, 2012 | 08:32 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Close, it watches the tach signal to ensure there's no over or under revving, there is also the option for voltage sense, or virtual tach which didn't respond well to the cold weather here in washington
Old Jan 6, 2012 | 08:28 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Semantics
Old Jul 2, 2012 | 11:13 AM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
im wanting to add a remote starter to mine, however i also wanted to add something one of my friends done who also has a KITT replica, hes tapped into the cruise control so he can remotely rev the engine which is really cool, you should see some peoples faces at the car shows we've been too !
so if i put a remote starter in, it starts the car, but then if i rev the engine with the other remote will it just cut out ?
Old Jul 2, 2012 | 11:37 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
If you use almost any DEI remote start they use the tach wire or the virtual tach to monitor the rpms, too high or too low and the remote start deactivates because the unit sees a fault. How he tapped into the cruise control circuit is beyond me, between engaging the cruise in park and what function the remote start does to actuate it. Idk. It seems like a pretty pointless thing to me, I generally show my system and car off at car shows not hide and rev my motor with a fob
Old Jul 2, 2012 | 02:24 PM
NINÅ's Avatar
Transmission: 765R4
Revolution Solution
You can use one channel on the key fob with a relay.
One set of contacts in the relay can open the park contacts, while another set of contacts is tapped into the accelerate portion of the cruise switch.
I recommend a rev limiter in case you lose remote control.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Jul 2, 2012 | 04:21 PM
gta_knight's Avatar
Car: 1987 GTA
he just tapped into the 12v wire i think, and its a momentary fob so it revs as little or as much as you want to hold the button, just to give it that knight rider vibe ? only thing is he doesnt have the remote start on his yet, he was just messing around one day and realised how to do the remote rev
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Aug 7, 2015 04:49 AM
