Wiring Harness Disaster
Old Sep 27, 2010 | 08:16 PM
houseumbrella's Avatar
Car: 1992 Camaro RS
Engine: 305 Throttle Body Injection
Transmission: Turbo-Hydramatic 700R4 four-speed
I got caught in the middle of a TPI swap because my wiring harness is missing a couple wires that have been clipped. but when i was taking my TBI wiring harness off i noticed that some wires went back to control the gauges and such. there were no such wires on my TPI wiring harness. do i need a seperate wiring harness for my gauges, or did someone clip those off, too?
Old Sep 27, 2010 | 11:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Wiring Harness Disaster
There should no be any wires from the pass side harness to the guages etc on a TBI car.
But - in the same location as the ECM, there is an electronic box that controls cruise control, and it will have wires running to the steering column.
There's also wires for the speedo from the VSS, but I have no idea where exactly this is located - when I swapped from TBI to carb I just left my wiring in tact and removed my ECM box.
Not sure if that helps.
Old Sep 27, 2010 | 11:15 PM
Car: 1992 Camaro RS
there are too many wires for just cruise, i think...but that DOES give me an idea. thanks, man
Old Oct 1, 2010 | 06:17 PM
Pocket's Avatar
Car: 91 Trans Am
Umm, not to be different, but TBI to TPI in a 90-92 car is plug and play. You need to bypass the buffer box and move the ECM speedo pin from pin D to pin K in the C207 engine side (clear)
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
