DiStRiBuToRs!!!
Old Sep 28, 2010 | 12:24 AM
houseumbrella's Avatar
Car: 1992 Camaro RS
Engine: 305 Throttle Body Injection
Transmission: Turbo-Hydramatic 700R4 four-speed
DiStRiBuToRs!!!
Are the TBI and TPI distributors the same? how about the coil pack? fuel pump? not looking to upgrade ANYTHING, looking to make a swap to TPI with the smallest amount of money as possible.
Old Sep 28, 2010 | 02:30 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: DiStRiBuToRs!!!
Both use the same computer controlled dist
Fuel pump on TBI is low pressure unit ; need to swap for TPI
hi - pressure pump
Old Sep 28, 2010 | 03:53 AM
Drew's Avatar
Re: DiStRiBuToRs!!!
The rumor is the TPI ignition module is different from the TBI module... They both work, but the TPI version is supposed to be specific. You can research it if you want to know more.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
