vss code 24
Car: 1987 IROC Z28 Camaro
Engine: Stock 305 tpi
Transmission: 5 speed manual
Axle/Gears: 3.08 posi
vss code 24
I have an 87 IROC, 305 tpi, 5 speed manual. I took the original gauge cluster out and replaced it with all new Autometer gauges. The old speedo was mechanical, the new one is electronic. Now, when I drive the car, I get a code 24, vehicle speed sensor. I have also noticed the idle dropping down when coasting to a stop. I know the vss on this car is only for supplying the ECM with information about the vehicle's speed. Question: Is there any way to wire the new electronic speedo input into the harness so the ECM is getting the info. If not, how can I get rid of the code? I like for the check engine light to work but I don't like seeing it on all the time.
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
Re: vss code 24
i apologize, but i do not have a solution for your problem, but i do have a question about the particular sensor.
my car has a carbeuretor, and cruise control, automatic trans, and a mechanical speedo. i have the same code (24) and have had it for quite some time.
what is it going to effect if it's not replaced?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
24 Plus One More
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
TMZIrocZ350
Oct 7, 2015 12:09 PM
