Does this connector go here?
Old Oct 4, 2010 | 01:38 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
The one with the yellow and black wires. Does it connect to this plug on the thermostat housing? I tried pushing it in for a couple of minutes but it wouldn't connect.. Maybe I have the wrong plug??
Old Oct 4, 2010 | 03:41 PM
Drew's Avatar
Re: Does this connector go here?
Someone replaced the pigtail for the coolant temp sensor. Both wires are black because it's a generic replacement. Since you can trace it back to where the wires are color coded (yellow/black) you know that it's a coolant temp sensor circuit, and that sensor on the water neck should be the right one. But there's no guarantee that the pigtail they crimped on there is the right one for the sensor.
Old Oct 4, 2010 | 07:31 PM
Pocket's Avatar
Car: 91 Trans Am
Wrong pigtail
Gray body means IAT, CTS is black. Look closely at the sides and compare to the ones in the sensor
https://www.thirdgen.org/forums/ltx-...erchanges.html
Old Oct 4, 2010 | 11:09 PM
0pyders's Avatar
dang...
ok. just to make sure. would this be the right one?
http://www.autozone.com/autozone/par...342421_0_6643_
Old Oct 5, 2010 | 08:33 AM
Pocket's Avatar
Car: 91 Trans Am
Thatd be the one
FWIW, grab one from a JY for pennies on the dollar compared to that
Old Oct 5, 2010 | 03:53 PM
0pyders's Avatar
Thank you Pocket. (and for that link too, nice.)
Old Oct 5, 2010 | 04:05 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Just to add a note on wire connections. If you must use butt connectors on sensor wiring, use the type with heat shrink on them. Butt connectors are not sealed and they will corrode causing resistance in the circuit. Sensor circuits are low current and very sensitive to resistance.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
