auxillary wiring?
Old Oct 14, 2010 | 03:28 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
auxillary wiring?
couple things. i do have some knowledge of electricity. but my electric fan doesnt work. it does but doesnt. my relay isnt gettin power and all my fuses are good. but instead of tracking down that. i was just goin to run the fan to a small switch panel im puttin in the car. and i plan on putting a sound system in the car too but im wondering where do i pull power from?? i know when i had my truck i had a small auxillary panel that i was able to tap into for power, but i dont know where in the car
its a 91 camaro rs v6
Old Oct 14, 2010 | 03:38 PM
Drew's Avatar
Re: auxillary wiring?
I wouldn't recommend doing what you're doing... But you can get 12v constant and 12v switched from the BAT, and ACC spots on the fuse block. Just keep in mind they're not rated for much amperage. You'll still want to get your power from the battery and wire your circuit with a relay and a proper fuse.
Old Oct 14, 2010 | 03:42 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I have an F'bird v6 and just did exactly that. The relay on the firewall was not the one shown in the manual. It's beside another one and they were swapped. Make sure you've got the right one! There should be a big red wire that's hot all the time, a smaller brown wire that's hot when the engine is running. There is another large wire brwn/blk(?) that goes to the fan and a small green/white wire that goes to the ecu and triggers the relay. I attached a wire to the green/wht wire and ran it to a switch with the other switch terminal grounded. Easy and works great. If you want it to work even with the engine off jump the red wire to the brown wire. All this assumes F'bird and Camaro have same set up. I think they do. Good Luck.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
