interior lights wont turn off
Old Oct 17, 2010 | 05:29 PM
saucy beast's Avatar
Car: 1989 friebird
Engine: V8 305
Transmission: after market automatic
i have an 1989 firebird, when i plug the crtsy fuse in the interior lights never go off, the door jams are correctly hooked up, the power mirrors and locks work, the hatch relase work, the dome lights work the only things that dont work are the horn, lights on the rearview mirror and the fact that the lights dont turn of, could a short in the line cause this, could a bad horn relay affect it, my car no longer has a power antenna and the wires for it are just hanging there could that affect it? i dont have a light bulb in the roof light could that affect it? any help please, any experiences like it please tell me your solution, thanks
Old Oct 17, 2010 | 05:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: interior lights wont turn off
The door jamb switches make a GROUND contact, not a power contact - so when the door is closed a ground is made for the interior lights.
Are there switches on the rear view mirror?
Have you twisted the headlight **** - twisting the **** dims/brightens the dash lights, and if it's twisted all the way the interior lights will stay on always.
Old Oct 17, 2010 | 05:53 PM
Car: 1989 friebird
Engine: V8 305
i have a button headlight switch and ive tried removing th switch and closing the doors but the lights still stay on, and there are two lights and two buttons on the rearview mirror i dont see how the door jams are not grounding out
Old Oct 17, 2010 | 06:35 PM
Drew's Avatar
The brightness wheel on the Firebird controls the courtesy lights... Just past full bright you'll feel a click and the dome light comes on.
Old Oct 17, 2010 | 06:49 PM
Car: 1989 friebird
Engine: V8 305
lolz the previous owners broke the actual spinning button so i never thought anything of it but i spun the inner gear with a screw driver and they went off but they dont turn on when i open the door, half the battle is won thanks so much, but still faced with the lights not coming on any help with that? tommorow in the light ill try the door jams to see if there grounding
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Omega
Aug 10, 2015 12:46 PM
