turn signals (yes again)
Old Oct 14, 2010 | 03:38 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
I got the brake lights switch replaced
brake lights work
park lights work
hazard lights work
head lights work
wipers work
dimmer works
no turn signals the lever will go up but won't stay and doesn't click
down it clicks but won't stay. they won't work regardless of which way I move it. rear bulbs have been checked.
ooohhh I also need a weather pack for my fuel pump (green/white wire) plug someone stripped a bunch of wires to splice something in and never insulated them and now they are touching and grounding the fpump making it run continuously. 6-wire plugs.
89 rs 305 stock 700r4
Old Oct 15, 2010 | 05:18 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Re: turn signals (yes again)
someone help please I promised my wife car would be inspected and registered by the 21st. Any ideas?
Old Oct 15, 2010 | 08:01 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
brake lights work
park lights work
hazard lights work
head lights work
wipers work
dimmer works
the lever that doesnt stay thats a hardware problem behind the steering wheel. with other words your gonna have to remove the steering wheel and look behind it.
do you mean your turn lights just stay on, or just stay out ?
if they stay on and dont blink ( and if both sides to this ) you can try putting a resistor parallel over 1 of turn signals ( a 27 ohm 5W ) should do the trick. 1 over every front turn signal.
what happens when you put your hazards lights on ?
Old Oct 15, 2010 | 04:51 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
when the hazards are on they blink normal and when I apply the turn signals they do NOTHING. and I do mean nothing. the not staying in place that is probably the cams not working but there is no blinking of the lights. Front and back lights work when the hazards are "on"
I am leaving work maybe I can figure this out this weekend
Turn signal Flasher? pull steering wheel and replace everything anyway?
Old Oct 15, 2010 | 05:03 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
is that thing that makes the blinking happen ( dont know the english name ) still working, its underneath your das has 2 wires in a connector going to it
Old Oct 18, 2010 | 05:23 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
sounds like your talking about the flasher and when I apply the turn signals no I do not hear the noise from the flasher. I do however hear the noise from the hazards flasher and have learned from TGO that the car has them seperated from each other. When I get off of work tonight I will be looking to locate and test the (turn signal flasher). although if I have to take the steering wheel apart to fix the hardware problem then I may as well get a whole new signal switch anyway.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
