im installing '85 t/a tail lights in an '89 formula, wiring issues...
Old Oct 25, 2010 | 12:11 PM
cougar7926's Avatar
Car: '89 Formula
Axle/Gears: 3:23
can anyone point me in the right direction for how to wire these together? they have diff color wires so i cant just snip and connect... ANY info is appreciated. idk where to start looking to fig this out. sorry i dont have the color of the wires atm.
Old Nov 10, 2010 | 08:57 PM
tuononero's Avatar
Car: 91 Firebird
Engine: 3.1L V6
Transmission: TH700R4
Re: im installing '85 t/a tail lights in an '89 formula, wiring issues...
did you solve that?
http://www.austinthirdgen.org/index.php?pid=37
Old Nov 11, 2010 | 12:32 AM
cougar7926's Avatar
Car: '89 Formula
Axle/Gears: 3:23
if you can call it solved...
i just plugged the 4 main bulbs into the GTA tail slots.
-outermost is the turn signal
-mid2 are running/brake lights
-inner most is reverse lights
they arent the exact same light pattern but ill live with it. also hada swap out the turning signal sockets for the ones off the GTA harness cuz the formula turning signal socket wouldnt physically fit with the GTA tails.
Old Nov 11, 2010 | 04:02 AM
tuononero's Avatar
Car: 91 Firebird
Engine: 3.1L V6
If you have a couple of hours of your time just follow the link i gave you.
That's what i did on mine yesterday.
But i spent the whole day because of other problems.
I had some 1982 trans am taillights i wanted to install on a 91 firebird.
The guy who sent me the 82 lights also gave me the bulb sockets.
To be honest i just had to use two of them (the running lights at the corners).
For the others i used the existing sockets from the firebird harness.
Some cuts, some joints and that's it, work is done.
If you want to try i'll help you out in case of problems.
Old Nov 11, 2010 | 08:43 PM
cougar7926's Avatar
Car: '89 Formula
Axle/Gears: 3:23
pm sent
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
LittleFranks
Aug 20, 2015 03:55 PM
Omega
Aug 10, 2015 12:46 PM
