LC-1 Gauge hook up question.....
Old Oct 25, 2010 | 10:03 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
The instruction says hook the yellow wire up to the headlight power wire (a wire that supplies current to the headlights and not connect this wire to the headlight dimming wire). So, my question is, can I hook it to the Dash light wire for the gauges or do I need to run the wire to the actual headlight power wire in the headlight switch?
Thanks.
Old Oct 26, 2010 | 09:28 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Yelling About The Yellow
That yellow wire to the headlight power deal is to dim the display when you turn on the headlights.
If you connected the
yellow wire to the dimmer it would work if you keep the dimmer at maximum brightness.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Oct 26, 2010 | 10:33 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: Yelling About The Yellow
Originally Posted by NINÅ
[B]That yellow wire to the headlight power deal is to dim the display when you turn on the headlights.
yellow wire [COLOR="NAVY"]to the dimmer it would work if you keep the dimmer at maximum brightness.
Ok...so I just need to keep the dimmer at the maximum brightness and it'll work. If I reduce it just a tad, what will happen?
Old Oct 27, 2010 | 12:23 PM
NINÅ's Avatar
Transmission: 765R4
Tad Poll
The display will go to full brightness if you turn the dimmer down.
Exactly what point on your dimmer dial is unknown.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
Bubbajones_ya
Jul 6, 2024 08:32 PM
69GTOby
Apr 18, 2016 02:34 PM
gta892000
Sep 16, 2015 12:37 AM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
