Fixing my Speedometer.
Old Oct 28, 2010 | 03:37 PM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
87 Firebird v6 Auto.
My Speedometer has started to jump up and down sometimes staying on zero.
i have the dash apart, the instrument cluster loose, Can pull it up to the stearing column.
looks like there should be three parts to it really? Speedometer, Speedometer cable, and the speed sensor.
I dont see a cable leading to the back of my speedometer. Just a sircuit board on back of instrument panel.
On my speed sensor there is a two wire connection. When I unplug this and drive around no check engine light and no speedometer reading.
I seen in one speed sensor replacement video, that the speed sensor had the cable go directly into it, along with the electrical wire.
My speed sensor only has the electrical wire and no cable going to it. Does this mean my speedometer is electrically driven and not mechanically driven, and there is no speedometer cable in my car?
Old Oct 29, 2010 | 02:13 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Fixing my Speedometer.
Yes. You also should get a CE light with the VSS unplugged (at the transmission). Are you sure the CEL is working ?
Old Nov 8, 2010 | 05:12 AM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
IDK about yours, but my speedo cable is hella tight, I can't move the cluster without first disconnecting it. Are you sure it didn't just get disconnected when you were pulling it out?
Reid Fleming
Oct 10, 2015 09:56 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
