NEGATIVE COIL HOOK UP HELP
Old Oct 31, 2010 | 05:33 PM
acdcfan37's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Open Diff
Im putting a tach in my 87 base model camaro and one of the wires needs to go to the negative side of the ignition coil. Which side is negative and can i pick it up some where else?
thanks
Old Oct 31, 2010 | 07:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: NEGATIVE COIL HOOK UP HELP
Most factory harnesses have all the wires installed regardless of whether a optional item is fitted or not
Tacho wire is white ( marked to int cluster from dist in diagram )
http://www.austinthirdgen.org/mkport...ine_wiring.gif
Look for wire under the dash or at cluster plug ( not used )
Failing that, connector is marked Tach on HEI dist cap next to the pink power wire
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Gordonr1973
Sep 29, 2015 11:59 AM
