TACH Wiring?
Old Nov 1, 2010 | 04:17 PM
acdcfan37's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Open Diff
TACH Wiring?
I have a 1987 base model camaro. just bought a tach and know where to hookup all the wires but one. The schmatic says it needs to go to the negative side of the ignition coil. Which wire is it? Can i pick the wire up somewhere near the fuse box?
thanx
Old Nov 1, 2010 | 04:27 PM
gp90gta's Avatar
Car: 1990 GTA
Re: TACH Wiring?
Its on the coil, if your not sure which one you can use a test light on it. It will be the one that blinks fast when the car is running.
Old Nov 1, 2010 | 07:23 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TACH Wiring?
If you have a HEI dist ,the terminal on the cap is marked TACH
Old Nov 8, 2010 | 05:09 AM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
Re: TACH Wiring?
on the distributor, the negative is NOT a ground
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
