Cables from somewhere :)
Old Nov 7, 2010 | 10:14 AM
shone190's Avatar
Hi,
does anybody know where those cables came from, precisely, where I need to connect them?
First three pictures shows one cable with two wires (black and yellow) with separated connector at the end.
On fourth picture you can see two cables (some ground cables), also not connected.
I don't know where to connect those cables
Car is Pontiac Firebird Trans Am GTA, 1988y, 350cid, with digital dash.
Thank you all in advance.
Best regards!
Old Nov 7, 2010 | 10:29 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Cables from somewhere :)
Yellow and black may be coolant temp sensor and the grounds connect to the back of the head .
Old Nov 7, 2010 | 11:39 AM
shone190's Avatar
No, this is not for Coolant Temp Sensor, CTS is connected and working.
Is there any "default" place at the back of the head to connect those grounds?
Thank you very much
Old Nov 7, 2010 | 12:54 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Find a bolt, bolt grounds to back of the head. It's irrelevant where just as long as it's from engine to chassis.
If the wires are tan and black instead of yellow, it might me to the MAT (manifold air temp) sensor which, is a CTS stuck in the bottom side of the TPI plenum. You should be able to see it looking past the 9th injector. It's right next to the EGR valve.
Old Nov 7, 2010 | 02:32 PM
shone190's Avatar
Thanks man, I had to go out right now with battery at 9:30h PM and fit this connector. I wouldn't find this MAT sensor ever by myself, and it's almost impossible mission to fit this connector, but I did it
Thanks man a lot.
Best regards!
Old Nov 8, 2010 | 02:38 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Good to hear you found it .
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
