Can a computer chip make a difference????
Old Nov 13, 2010 | 04:44 AM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
I've replaced my 305 with a 355 in my 91 RS Camaro, I'm having a hard time getting it to stay running. A suggestion was given that the computer chip in the computer might need an upgrade as well. On the other hand I've also have been told that the stock computer would adapt to the changes, just fine?? Does anybody actually know the truth of this???
Old Nov 13, 2010 | 04:59 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Can a computer chip make a difference????
TBI or TPI? a 91 305 I believe is MAP, generally when you mod, a MAF system adapts better to a modified engine than a MAP , however since you have a completely different setup, you will have to change some tables, which ones? don't know...
Old Nov 13, 2010 | 06:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I've also have been told that the stock computer would adapt to the changes just fine??
Not for a completely different size engine
For starters, the computer thinks the 305 injectors are still in the engine so fueling will be off
A chip from a stock 91 350 would get you ball park
Old Nov 14, 2010 | 04:07 AM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
it is TBI, thanks
Old Nov 14, 2010 | 04:09 AM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
what does MAP and MAF actually mean?
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
Exxon Limited
Aug 9, 2015 08:13 PM
