good battery ground?
Old Nov 13, 2010 | 01:42 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Right now my battery is grounded on my alternater bracket. I am wanting a better ground. If frame good spot?
Old Nov 13, 2010 | 02:18 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: good battery ground?
your main ground has to go to the engine because of
the heavy current pulled by the starter motor-the
ground cable to the alternator bracket can be moved
to another large bolt on the engine such as on the
front of the head,the threaded holes on front of the
block or the fuel pump block off plate if there is no
fuel pump in place. If you have accesories on the car
that pull a lot of current,you should run an extra
ground wire from a good ground on the engine to the
crossmember-the extra ground should be around 6GA.
or bigger.
Old Nov 13, 2010 | 02:46 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Main gound would be the one off battery? That is the one going to alternator bracket.
Old Nov 13, 2010 | 04:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Main ground wire from battery goes to engine (usually where you have it, on the alt bracket). You also have to have a ground from engine block to frame (usually pass side head to firewall), and there's also a smaller ground wire runs from battery neg to fender. ALL three have to be in place, to complete the circuit (battery to motor, motor to frame, frame to battery).
Old Nov 13, 2010 | 04:42 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I just put it on alternater bracket but on low part where it bolts to head. Beings my car has a sawpped 327 in it the brackets are rigged together and it was on the alternator bracket but high on it in a drilled out hole. I will check other grounds. I am just trying to figure out why anytime I turn on lights, heat, signals or anything else my volts jump around. Figured good ground is a good place to start
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
