TCC wiring up..
Old Nov 13, 2010 | 09:56 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
TCC wiring up..
I am in the process of wiring up my Torque Converter. I have installed the FAST fuel management system in and am a little stumped. From the Factory plug off the transmission I have 3 wires that go to the TCC on the transmission ..
According to the GM Mitchell Manual for 1987 Camaro the wires are.
1. LT BLU wire which is for the Top Gear Switch
2. PPL which is for the TCC Solenoid to the Brake Switch
3. Tan w/Blk which normally goes to the ALDL connector
When I look at the wires, they actually are Green, PPL, and Tan w/Blk.. Not a big deal. I will use the green for the LT BLU..
Am I under the correct assumption that I should use the LT BLU or Green wire for the TCC? The PPL and Tan w/BLK should only go to the ALDL and Brake Switch.. I am thinking so when you tap the brakes, The TCC unlocks. Please let me know if I am thinking this correctly. I can scan the image from the manual if needed.
Old Nov 13, 2010 | 11:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: TCC wiring up..
Ground the tan/black wire on pin D to lock the TCC.
Old Nov 14, 2010 | 12:24 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TCC wiring up..
Originally Posted by ibmtech
PPL which is for the TCC Solenoid to the Brake Switch .
Reread your diagram .
12V comes through the brake switch to TCC solenoid .TCC is controlled by going to ground at ECM ( tan /blk ).When brake switch opens it cuts off power to TCC
As shown in diagram ,it goes to ECM ; also Tee's off to ALDL connector so you can test TCC operation by grounding terminal
Old Nov 17, 2010 | 12:31 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Re: TCC wiring up..
Ok then what exactly does the LT Blue wire do?
Old Nov 17, 2010 | 12:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: TCC wiring up..
Tells the ECM when the transmission is in O/D.
Old Nov 17, 2010 | 06:54 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Re: TCC wiring up..
ok, So in my case, I am using a FAST XFI computer. The Blue wire would go to the TCC?
Old Nov 17, 2010 | 07:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: TCC wiring up..
Not if the computer is going to control the TCC.
jklein337
Sep 19, 2018 06:23 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
