4th gen gauge cluster swap
Old Nov 14, 2010 | 07:09 PM
McTavish55's Avatar
Car: 1986 Camaro Sport Coupe
Engine: LG4 V8
Transmission: 700 R4
I have an 86 Camaro, and i'm considering swapping out the old gauges with a set from a 4th gen. I've seen some threads on here about people swapping them in, but I haven't seen any instructions on how to do this.
How hard is it to do this, and how much wiring is involved?
If anybody could help me out it would me much appreciated.
Old Nov 14, 2010 | 08:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th gen gauge cluster swap
Welcome to TGO.
The 82-89 cluster with a mechanical speedo is shaped much differently than the 90+ with its electrical speedo. The fab work to make the later fit the earlier would be considerable.
JamesC
Old Nov 14, 2010 | 09:48 PM
McTavish55's Avatar
Engine: LG4 V8
Fitting aside, what would have to be done to make the newer gauges compatible?
Do you know of any nice aftermarket gauge clusters that are compatible, and not too expensive?
Old Nov 15, 2010 | 06:29 AM
JamesC's Avatar
I'm unsure, though the speedo, since it's electric, may be the biggest obstacle as your 86 is mechanical.
Here's a Covan installation--I doubt you'll find any 'cheapies' (and to my knowledge, none are plug and play):
http://www.chevyhiperformance.com/te.../photo_04.html
JamesC
Old Nov 16, 2010 | 09:52 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
wiring wise, you've got to rewire everything; the connections are completely different. you'll also need to get one for an LT1 setup (93-97), since the gauges were run off the serial data on the LS1 models. then comes the cutting you'll need to do to get the gauges to sit in place.
not a quick and simple swap by any means unfortunately. if you're looking to do it up, start browsing through the 4th gen dash swap articles, as the wiring info should be there
Old Nov 16, 2010 | 11:03 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
https://www.thirdgen.org/forums/inte...ring-good.html
that's a good start for the 4th gen pinouts; the ones in your vehicle may differ for the 3rd gen stuff. I had a helms manual handy to trace out my stuff in my TA
Old Nov 20, 2010 | 07:37 PM
McTavish55's Avatar
Engine: LG4 V8
Thanks for the information.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Casey Meyers
Mar 2, 2016 10:46 AM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
