Dim Headlights
Old Nov 19, 2010 | 06:50 PM
Fla88Roc's Avatar
Dim Headlights
I have an 88 Iroc none of the headlights are the same brightness. Three are so dim they are worthless and one is extra bright. Flip the brights on and they all change to different levels and none of them are the same brightness. I have never seen anything like this before and have no clue where to begin. I thought about switching all the bulbs but don't want to waste the money if somebody else has already seen this.
Any help???
Old Nov 19, 2010 | 08:57 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Dim Headlights
you/we have cars that are 20+ yrs. old . clean ALL connectors , headlights prongs etc. . corrosion is like a cancer it needs to be removed . my thoughts are that you have dirty/corroded conections . a good cleaning and a lite coat of di-electric grease would help on all the connections . of course you may also have some old/weak sealbeams . but , clean all connections first . good luck .
Old Nov 19, 2010 | 09:11 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Re: Dim Headlights
Any help???
Try cleaning all the GROUND connections. Sounds like faulty grounds to me.
Old Nov 19, 2010 | 09:13 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Dim Headlights
if its anything like my car where it still had the factory headlights i would replace those aswell...i had all original headlights and only one was blown but i went ahead and replaced all of them...the bulbs are only $10 a bulb, so $40 for all 4 is pretty good i think.
Old Nov 23, 2010 | 01:00 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Re: Dim Headlights
Check and clean/fix your grounds
Old Dec 20, 2010 | 06:42 PM
Fla88Roc's Avatar
Re: Dim Headlights
Thanks all of you guys for the responses - I cleaned the pig tails and the prongs on the sealbeams and they are all working great now. I am going to take the advice to replace the lights themselves though. Thanks again!!!!
Old Dec 20, 2010 | 07:50 PM
Davidgou's Avatar
Re: Dim Headlights
You're very welcome, I'm glad it worked!
SRKLEGIN
Oct 29, 2015 06:38 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
