MAT too high
Old Nov 27, 2010 | 01:06 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
MAT too high
Hey, my check engine light has been on since I bought my car and I finally got around to checking it. It read that my MAT was too high. I searched all around and found no answers. what is MAT and how do I fix it?
Old Nov 27, 2010 | 02:28 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: MAT too high
Manifold Air Temp sensor.
Old Nov 27, 2010 | 11:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: MAT too high
If you have a stock air cleaner housing, it's that thing on the bottom you have to unplug to remove the air cleaner. It's a two wire plug. Perhaps it's not plugged in or even there? That connector needs to be plugged into one whether it's in the cleaner housing or relocated to a cooler spot where it may cause it to run leaner and not retard the timing from heat soaking. Maybe it's plugged in and hanging down by the exhaust. That's too hot
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ULTM8Z
Oct 2, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
