How do i create a switch that turns on my fans?
Old Dec 20, 2010 | 08:31 PM
SSZ2891's Avatar
How would i create a switch to turn on my fans cuz im not sure they ever come on and also i want my engine to run as cool as possible.. thanks guys
Old Dec 20, 2010 | 09:34 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: How do i create a switch that turns on my fans?
lots and lots of different thermostats are avalible to
control the electric fan;some just replace the original
thermostat in the head,some have a thermistor probe
that pokes into the radiator fins and controls a circuit
board that switches on the relay,some have a thermal
bulb that connects to a switch with a capillary tube.
There are other styles as well.
The radiator fan on my car is belt driven,but my oil and
tranny coolers have their own electric fans;for the oil fan
i used a spare chevy citation fan switch-just tapped
my oil filter adaptor for it ans threaded in,it grounds
a relay to activate the fan.For the tranny i used a
capillary tube style adjustable thermostat.
For the engine running temp,you don't want to run it
"too cool"-if it is running too cold the cold oil film on
the cylinder walls will be stiff causing extra friction,
gas will condense on the cylinders washing the oil
film causing wear and diluting the oil in the pan
i run mine at 195*,i'd say 180-230 is a good range
-a lot of nascar engine builders like to run their
engines at around 230*
you do want the air going into the engine to be cool
though-you get a denser mixture into the cylinders,
therefor more power potential
Old Dec 21, 2010 | 07:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by carralo1
...cuz im not sure they ever come on....
Perhaps you should verify that your fans aren't functioning before you explore other options.
JamesC
Old Dec 21, 2010 | 09:00 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You splice a wire into the fan(s) relay control wire and run that to ground through a switch
Switch off ; computer controls fan
Switch on ; fans run when ever you want
Old Dec 21, 2010 | 12:38 PM
Pocket's Avatar
Car: 91 Trans Am
Best way
Here is the stock LO3 fan diagram for your 90
http://www.austinthirdgen.org/mkport...an_V8_vinE.jpg
Its controlled by a thermal switch in the pass cyl head between #6 & #8 primaries. Make sure its in working order. If you still want a manual override switch, tee into the wire and take it to ground at the switch. On means fans run constantly with the IGN on, off means the thermal switch controls on/off
Old Dec 21, 2010 | 09:33 PM
SSZ2891's Avatar
ok tomorrow im gonna check if my fan functions properly..
then if so i will start to work on the switch.
thanks for the help guys. im gonna try the method vetteoz suggested. seems simple and exactly what im looking for
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
TA8487
Aug 16, 2015 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
