want to check codes as described in FAQ
Old Jan 1, 2011 | 12:19 PM
jacklieb's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5-Spd
Axle/Gears: 3:08
Where is the OBDI - DLC type connector to jump the pins? I found one near the fuse panel with an empty connector but I'm not sure thats it, it does not look 'D' shaped. TIA - Jack
Old Jan 1, 2011 | 03:24 PM
jacklieb's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5-Spd
Axle/Gears: 3:08
found it...
it was right next to the fuse panel, and was not 'D' shaped at all. I decided to try anyway. The worst thing that could happen is to blow a fuse (I hoped). On my car (91 RS L03), you had to jumper pins 5 & 6, not 6 & 12. But anyway I got a 42 code and im going to search for 'code 42' now to see what other members experiences may have been.
Thanks - Jack
Old Jan 1, 2011 | 05:41 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: found it...
http://www.gnttype.org/maint/malf.html#42
Old Jan 1, 2011 | 05:44 PM
jacklieb's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5-Spd
Axle/Gears: 3:08
problem solved
after spending 2 to 3 hours searching for 'code 42' and reading what the possibilities were for this code, I found the tan wire that completes the EST circuitry was broken (the one we disconnect to set base timing in the loom near A/C). A little solder and a quick reset of the codes and viola! It even runs better now it seems.
Thanks for being such a good resource for my new project car. This is the newest car I've ever taken on as a project, so I'll be back many times before I'm finished.
'91 RS L03, 5spd - future recipient of 420HP 383
Thanks - Jack, Nashville
Old Jan 1, 2011 | 07:05 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: problem solved
I found the tan wire that completes the EST circuitry was broken It even runs better now
It would
You had no computer control of spark advance before
chazman
Aug 28, 2018 03:25 PM
InfinityShade
Feb 21, 2016 01:29 PM
chazman
Aug 22, 2015 02:01 PM
mizz0313
Aug 12, 2015 06:45 AM
