radio problem
radio problem
i have a 91 firebird v6 3.1 ok heres my problem i had a factory radio i wanted to switch it out with a after market radio so i pulled out the old radio an i accidently cut the main harness i dont know why i did that but when i realize it i repaired the wires matched them back up and now my radio doesnt work all of the wires are correctly matched an i got a test light and tested the wires i have one power wire when the key is on im pretty sure i should have two an i checked my radio fuse it was ok any ideas??? thanks Mike
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: radio problem
yes you should have a constant power (orange wire is almost always the constant) and ignition power acctualy you may of poped your constant power accessory fuse does your dome light footwell lights come on?
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
