need help wiring
Old Jan 13, 2011 | 04:31 PM
8732's Avatar
need help wiring
Im running a fan switch and fuel pump switch i need to know what i have to get and how to pull this off what. Gauge wire what fuses and what amp toggle switches to use please help soon
Old Jan 13, 2011 | 04:39 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Re: need help wiring
Why are you putting switches on? Did you do away with the key?
Old Jan 13, 2011 | 04:54 PM
8732's Avatar
I am working on a rebuilt since i dont have vats i decided to run switches. I still have key to unlock column just running switches since its a prostreet set up
Old Jan 13, 2011 | 05:03 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
I can't answer everything you want without looking at the amount of power the fuel pump and fans you will be using pull. However, if you are doing this because things are working right. You can just buy an aftermarket fan switch and they come with pretty much everything you need so your fan will turn on and off when necessary only. Fuel pump should turn on and off with the key. If it is not then the likely cause is the relay or a bad ground. If you must put in switches, find the amount of power that the fuel pump and fans you are installing pull and then it will be easy for you to find the right size wire, switch, and fuses.
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Here's the wiring diags: http://www.austinthirdgen.org/index.php?pid=19
Old Jan 14, 2011 | 10:06 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fan Club
Don’t use switches only, use a relay as well.
Here is a fan circuit which ingeniously shuts the fan off
(in case you forget to turn off the switch) when you turn the car off.
Happy Racing!
I’ll Bump You Once To Move Over, Next Time I’ll Spin You
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
