Temp gauge
Old Jan 15, 2011 | 11:18 PM
VandykeT/A's Avatar
Temp gauge
My 86 temp gauge has started going crazy. It shows 100 most of the time with the occasional trip to 220 or pegged out. It grounds when cranking and I've had 2 new sensors in it and still the same thing. Sometimes it will seem to work right and then it'll start twitching. What else could cause this ? Thanks
Old Jan 16, 2011 | 09:01 AM
oif0709's Avatar
From: http://www.facebook.com/ThirdGenCamaroFirebird
Car: 1987 Camaro Z28
Re: Temp gauge
check your wires go to the sensor from the gauge. make sure there are no cracks or split that could cause it to short out. i was having the same problem and my issue was the wires that where actually plugging into the sensor had a back connection. so i had to pull the wires out of the plug and just touch them to the sensor. i wouldn't recommend doing it that way if that is what the problem is, but these are just some tips. mine works perfect now though
Old Jan 20, 2011 | 09:00 AM
VandykeT/A's Avatar
Re: Temp gauge
No cracks, it goes back into a big harness and its a little green wire. I cut the plug in off and just wrapped the wire around it and still does the same thing. It seems as if it works more accuarately when you turn the car off. Like it could be pegged out running and when you kill the engine it goes to a quarter of the gauge but when you turn teh key back on it goes crazy again, I'm starting the think the gauge is just bad.Thanks
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
