HELP!!!!! 1982 -1992how to get at running lights bulbs????
Old Jan 23, 2011 | 02:40 AM
travisgold's Avatar
Car: 1984 Camaro Z28
Park/DRLS how do i get at the bulbs in the DRLS on the front passenger side i dont mean the headlights or the side lights but the front DRL Signal light bulb i have no clue how to access it please help me
Old Jan 23, 2011 | 04:56 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: HELP!!!!! 1982 -1992how to get at running lights bulbs????
How many times do you think you really need to post this very same question?
Old Jan 23, 2011 | 12:53 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I think if you crawl underneath the bumper and look behind the light assembly, you should see the bulb socket. It should be a twist and then pull type of socket.
Old Jan 23, 2011 | 03:44 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
jack the front end up, look under neath on that side, you can get to it without moving anything. The drivers side is the hard one.
Old Jan 23, 2011 | 04:07 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Just lay on the ground, reach around behind it , and when you twist the socket counter-clockwise like unscrewing almost everything about a quarter of a turn it will come out. Remove bulb the same way. Repeat steps backwards, turning clockwise to screw in and it's done
Old Jan 23, 2011 | 09:47 PM
travisgold's Avatar
thank you all for the help i got at it the bulb inside broke right off when i was removing it so i had to use plyers to remove the socket once i removed it replaced the bulb i got full signals now i was wondering though i think my light switch also is faulty i have no low beams only highs when i switch on the highs 4 bulbs come on like it should but when i switch to drls the lows dont come on
Old Jan 23, 2011 | 10:02 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Most likely the switch that changes from high to low beams needs adjusting. It's what is actuated by the rod that moves when you pull back on the turn signal stalk. There's a whole bunch of threads on here with all the details. Do a search for hi-lo beam switch. Takes a little bit of time but it's not hard at all. Take off the panel under the steering wheel and watch the rod that moves down the column and you will find the switch where the rod ends. Push in on the switch and when it clicks now at least you have low beams. If you don't find enough info, somebody can walk you through it. Let us know what you find
Old Jan 23, 2011 | 10:04 PM
travisgold's Avatar
thank you i will probably do it in the next day or two
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
