OK, what is this and why is it unplugged?
Old Jan 23, 2011 | 02:54 PM
alistair's Avatar
OK I have a 1988 Trans Am GTA and I was pulling the dash today to replace the heater core (what a job that turned into, but I digress)
Anywas I found this multiplug in the passenger side dash and it is unplugged.
I wondered if anyone knows what this is for and any suggestions why a previous owner has unplugged it?
FWIW most of the electrical "accessories" in my car don't work but I haven't chased them all down yet. I'm trying to get the mechanical stuff done first.
Its the kind of pale blue coloured plug.
Thanks in advance.
Old Jan 23, 2011 | 03:51 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: OK, what is this and why is it unplugged?
The one plugged in above it is for the power antenna. Without that one plugged in, the antenna will not go up or down because there won't be any power to the motor. Maybe it's the connector for when you turn the stereo on/off the antenna knows to go up and down?
Old Jan 23, 2011 | 04:46 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Looks to me like maybe the antenna is shot and that connector is unplugged to keep the battery from dying overnight. Had the same problem with my Grand Prix until I fixed the antenna. I'd guess that the antenna mast needs to be replaced and the PO either didn't know how to do it or how to get at the antenna assembly to do it (early models are easy).
Old Jan 24, 2011 | 10:05 AM
alistair's Avatar
OK, thanks that all makes sense!
db057
Jan 10, 2020 08:55 PM
db057
Apr 28, 2019 07:45 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
earlpote
Sep 12, 2015 11:55 AM
