1984 Wiring Diagram for Rear Hatch Switch
Old Jan 26, 2011 | 09:47 AM
rockstarr4's Avatar
Car: '84 Camaro - 2010 Surf Blue
Engine: 305 - 4 bbl Holley
Transmission: WC T5
Axle/Gears: 3.08
I need help finding a wiring diagram of my hatch switch circuit. My manual does not show this circuit for some reason. I'm converting from a 700R4 to a T5 and looking at the wiring that went through the gear selector switch on the auto shifter. There is a yellow wire that goes to the neutral switch, but also goes to a relay that is connected to my hatch switch.
I need to trace this as I won't have the neutral switch once I'm done with my T5 conversion and I want my hatch to open as usual.
Anyone have this diagram to share?
Old Jan 26, 2011 | 10:31 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Van Halen Says Jump !
You can jump the yellow wire to the purple wire which went to the neutral switch.
First use an ohmmeter at the switch to verify that they are the correct wires.
By jumping, you won’t have to worry about the relay.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Jan 26, 2011 | 02:10 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Re: 1984 Wiring Diagram for Rear Hatch Switch
I understand what you are suggesting, but the purple wire is going to be used on the clutch switch (in place of the neutral switch) to prevent starting in-gear.
What I don't understand is how the yellow wire from the ignition start switch is also used in my hatch circuit? I'm thinking that they might have tied the hatch circuit in with the neutral switch somehow so you can't open the hatch when in drive or reverse. But without the neutral switch anymore, I must have to do something else to make my hatch switch work.
I'm hoping someone has the hatch circuit diagram for 84 that I can look at.
Old Jan 26, 2011 | 03:04 PM
NINÅ's Avatar
Transmission: 765R4
The other end of the yellow wire goes to the hatch relay.
It grounds the relay coil enabling the relay to function when you hit the hatch release switch.
The reason the wire also goes to the “start circuit” is the designer grounded the hatch relay thru the starter windings.
Therefore you will be able to connect the wires which now go the automatic shifter to the clutch switch so you can’t start it in gear.
Then you can prevent the hatch from opening while the car is in motion by using the P-brake switch to keep the hatch circuit disabled when the P-brake is on.
If you intend to retain the P-brake light, you might want to use diodes or a relay to isolate it.
Happy Racing!
Old Jan 26, 2011 | 03:35 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
You seem like you're on the right track there with the yellow wire from the ignition switch and the purple wire from the starter going to the neutral safety switch now instead of the gear select.
There should be a yellow wire on your hatch release relay. Automatics it will be connected to your selector switch, manual it connects to the e-brake switch. It completes the ground when the e-brake is applied allowing the relay to work when the button is used to unlock the hatch.
Old Jan 27, 2011 | 12:42 AM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Thanks to both of you guys for the advice. Tonight I connected the yellow wire from the hatch relay to the parking brake switch and it works like a charm. I kept the parking brake lamp wire connected as well with no diode or relay and both the lamp and hatch work when the e-brake is pulled. Problem solved!
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Caspar
Jun 19, 2016 11:19 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
