Wiring
Old Jan 26, 2011 | 09:22 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Wiring
Quick question. Did 82-92 Camaros come from factory with a wire loom wire harnes? I was just wondering because nearly all of my wire harness is done in electrical tape, with just some of the ends using wire loom. Old electrical tape is nasty when you need to take it off, just makes a huge sticky mess.
Old Jan 26, 2011 | 09:37 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Wiring
They would have the wires loosley taped (just enough tape to hold wires in a bundle)with loom around them.
Old Jan 26, 2011 | 10:01 PM
Car: 1990 Camaro RS
Re: Wiring
Thanks! Alright thats what I was wondering. Theres almost no wire loom and most the harness is completely taped so its likely somebodys mess. It just seemed like alot of work for somebody to do. it was done to wiring through the dash, from the ECM into the enginge bay, and even under the carpeting.
Old Jan 27, 2011 | 08:16 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Wiring
It was loomed with tape at the ends of the plastic to keep them together and every intersection. Very few runs were wrapped continuously with tape
Your 90 should be nearly all plastic split loom
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
