Is It Safe To Run It This Way?
Old Feb 5, 2011 | 07:52 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Ok, heres the situation. I have a Racetronix fuel pump in my car, Ive got it wired up and I am debating on how to run this last bit of wire. The wire in my hand in the photo is the wire going down to the fuel pump relay at the rear of the car. Obviously you see the fuse in the middle. Now the last wire with the ring terminal is supposed to be connected to the terminal at the back of the alternator. Now this is my dilemna, I am trying to clean up the wiring in the engine bay, this being one of them. If the terminal at the end of the alternator has constant power at all times, couldnt I safely run that wire directly to the battery without fear of the fuel pump running at all times? Any input would be appreciated, thanks..
Old Feb 5, 2011 | 08:19 PM
Twin_Turbo's Avatar
Re: Is It Safe To Run It This Way?
Yes, can be run directly off the battery and it'll be all good since you have it fused. That's exactly how mine is set up.
Old Feb 5, 2011 | 08:33 PM
Copchaser's Avatar
I thought so! I just wanted to double check. Thanks Twin
Old Feb 6, 2011 | 07:28 AM
Pocket's Avatar
Car: 91 Trans Am
The output stud on the alt is connected directly to the battery so both points would give 12v constant
Old Feb 6, 2011 | 09:47 AM
Copchaser's Avatar
Thats what I was thinking also but I was tired and my head was a lil fogged on the whole thing. Like I said, Im just trying to clean up the wiring a bit, make it all look a lil bit more appealing.
Old Feb 6, 2011 | 05:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The object of the Alt connection with pump hot wire kit is to give max Voltage to pump.
Racetronix site claims 1V+ difference between Alt and batt terminals when engine running
As pump performance is directly related to Voltage then this gives max pump output
Old Feb 6, 2011 | 06:15 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
If there's a 1V+ difference between the charge connection on the alternator and the battery connection, there are electrical system issues. That being corrosion or inadequate main charge lead between the alternator and battery.
eightsixseven
Dec 16, 2024 01:50 PM
Grant2k
Jul 10, 2018 04:01 PM
Polo Z03
Sep 10, 2015 06:43 PM
ezobens
Aug 19, 2015 10:29 PM
BlackBoulder
Aug 11, 2015 11:15 PM
