Blinker Trouble!!!
Car: 1987 Fire Chicken
Engine: 305 ci
Axle/Gears: 10 Bolt Posi 3.73 gears
Blinker Trouble!!!
Hey guys, I need some help with my signals, maybe you would have the answer. When i select the lever the signals just stay on instead of blinking, but the hazards work. I changed all the bad tail lamp bulbs but no dice. Im thinking its a fuze, any idea where or which one?? Supreme Member
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Blinker Trouble!!!
Bad bulb will make that happen - just because a front park light works doesn't mean the bulb is good - park lamp and turn signal use different element inside the bulb (like park lamp/brake lamp does).
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
